Re: 67 Wheel bearing saga- Unbelieveable
that is the reason i take out the spring and ball check in the grease fitting because after filling the cavity with grease when you remove the grease gun the extra grease and pressure come back out the grease fitting. "bearing buddies" that are used on trailer wheels to grease them use a "pop off" vent so you know when the cavity is full of grease
