Guys
Would like some opinions on my recent electrical problem. I recently had a total electrical failure on my 67 400HP A/C car. Thought it would most likely be be the usual firewall connector that I have read about here, but found something different.
When I opened the hood I found about 3 or 4 inches of the red altenator wire burned to a crisp up to and including the altenator post and the rubber insulating boot. The altenator post seems to be loose and I think that is my problem. I have sent the altenator to Mr. Pirkle.
Is there a way to check my voltage regulator? This one is a Delco replacement, IIRC it may be solid state.
Can some one who has been there, done that tell me how I might best replace the altenator red wire safely. I like to try to keep original stuff if I can and the only affected wire seems to be the last (or first) three or so inches of the red wire. I have looked at wiring diagrams and it looks like the red wire splices into some other wires on its way to the starter, but it is not clear to me where this occurs or exactly what type of connectors I will encounter or have to replace. I have not unwrapped the harness yet.
If anyone knows where I might find the correct, original type insulating boot I would appreciate that too.
Gary
Gary
I can picture the illustrations in the Chassis Service Manual, though. I'm sure the testing instructions are there.
