E66 Dash Paint question - NCRS Discussion Boards
  • Rod M.
    • July 30, 2008
    • 36
    I have a E66 black dash with some key rash. Can anyone tell me what paint to use for touch up?
  • Gary B.
    • February 1, 1997
    • 6979
    E66 Dash Paint question; Will Tuxedo black lacquer work?
    Rod,
    Are you talking about a gloss black part of the dash? I need to repaint the gloss black areas on the inside of the doors on my '66 coupe and I think a paint that will work is Tuxedo black lacquer, which is a Corvette color, and I think one can buy this in quarts from one of the places in the country that sells lacquer.
    Gary
    • Rod M.
      • July 30, 2008
      • 36
      Re: E66 Dash Paint question
      Good question. It is the instrument cluster and it appears tobe semi-gloss. I also have some scratches around the speaker and the paint appears tobe a flat black. Are you aware of a brand that will work to touch up?
      • Brian T.
        • September 30, 1990
        • 188
        Try to find some of that good old Krylon 1613 semi flat black. Make sure the surface is good and clean. It will be a great match, as long as the existing paint is original, or if it was repainted properly.
        • Donald T.
          • September 30, 2002
          • 1319
          Used good ol' Krylon 1613 on mine before it became extinct.
          https://www.forums.ncrs.org/attachme...95347&uid=5347
            • 11608
            SEM Trim Black, original color (3914)
            Absolute perfect match for color and sheen.
            Patrick
