Clipping corners off rear steel spring - NCRS Discussion Boards
  • Steve L.
    • June 30, 2001
    • 763
    My original rear leaf spring broke right in half under the clamp(main leaf). It's the 9 leaf 73 small block. The spring is chamfered at the corners on the main leaf.
    Dr Rebuilds is not chamfered. Is it possible just to grind off these corners to match the original?
    Steve L
    73 coupe since new
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
  • Donald T.
    • September 30, 2002
    • 1319
    Re: Clipping corners off rear steel spring
    Steve,
    You can get reproduction rear springs that are very close to the original configuration from Eaton. They have the curled ends as well as the 45 degree angles on the ends of the main spring. Here's the link.
