Correct Choke Tube 65 L79 - NCRS Discussion Boards
  • Donald T.
    • September 30, 2002
    • 1319
    Anyone know if anyone makes a correct chrome plated steel 65 L79 upper choke tube?
    Corvette Central and Paragon only have stainless (non magnetic). LICS has chrome plated steel, but the configuration of the bends are all wrong. It won't even come close to fitting. The pic has the LICS part on top and a stainless part that does fit properly below. It's not even close and I assume it is for a different application entirely. After sending the pic to LICS and arguing with them for some time, I finally gave up. Apparently their source is Zip and both insist the item pictured on top is correct and fit fine in testing (not true). Anyway, I'm still in need of a correct part.
    Thanks!
    Re: Correct Choke Tube 65 L79
    The upper tube in the LICS bag is clearly mis-identified/mis-packaged; it's for an AFB application. The lower one is correctly configured.
    • Donald T.
      • 1319
      Thanks John. That's what I suspected. Surprising LICS was so dismissive. The lower one got dinged in judging because it is non magnetic.
