Corvette Rubber Roadster Vent window - NCRS Discussion Boards
  • Mike M.
    • September 30, 1999
    • 710
    In the pictures the vent rubber on the outside of the door does not come all the way to meet the back rubber and close the gap. Can a few of you look at your roadsters and see if this is correct. These rubbers are from corvette rubber and they say thats the way they are made. It just does not look right.The vertical post will move a little closer once the screw and stop are put in and close the gap at the inside of the window. I sent the pictures to Corvette rubber also, they said that there correct and made to GM drawings. Anyone else have corvette rubber in there roadster vent windows and have this problem.
    Thanks Mike
  • Bob R.
    • June 30, 2002
    • 1595
    Re: Corvette Rubber Roadster Vent window
    When I replaced the rubbers in my vent windows I compaired the Corvette Rubber materials to the original and I didn't notice any difference in size or shape. The vent windows really don't close or open or seal as well as I would like but I think this is just the design.
    • Paul J.
      • September 9, 2008
      • 2091
      Mike:
      The original verticle back rubbers on my 64 stand out slightly, similar to the ones in your picture. The outside rubber meets them at the top and there is no gap. All of the rubbers are original and have not been replaced.
      Paul
      • John D.
        • December 1, 1979
        • 5507
        Mike,There was a fellow on the utter side I believe that asked the same question. Go and talk to him about how he solved the problem.
