350hp - mt - Flywheel Specs - NCRS Discussion Boards
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    My engine machinest/builder wants to confirm diameter and tooth count on flywheel of above. TIA, Dennis
    Re: 350hp - mt - Flywheel Specs
    Dennis-----
    For 1967 L-79 (350 hp 327cid) a 12-3/4" flywheel was originally used which had 153 teeth on the ring gear.
    Only TWO size flywheels were EVER used for Corvettes at least through 2004 and as follows:
    C1----all were 14", 168 tooth
    C2----all 327, 396, and L-88 were 12-3/4", 153 tooth; all 427 except L-88 were 14", 168 tooth
    C3----1968 with 327 and all L-88 were 12-3/4", 153 tooth; 427 except L-88 were 14", 168 tooth
    1969-81----all 14", 168 tooth except L-88, ZL-1, and ZR-1. L-88, ZL-1, and ZR-1 were 12-3/4", 153 tooth
    C4----all were 12-3/4", 153 tooth
    C5----all were 14", 168 tooth
