anybody know of a source for offset a-arm shafts that would allow for more negative camber in a c-4. Old Farm Use needs more --cording front tires at a terrible rate. have gone as far as i can with standard suspention technique to achive camber that's currently not negative enough.mike
c-4 negative camber
Re: c-4 negative camber
Mike-----
I don't know of any source for such upper a-arm shafts. As a matter of fact, you could never even get the original shafts from GM as separate pieces. They were only available as part of the complete arm assemblies.
While Federal-Mogul/Moog does offer off-set shafts for 63-82 Corvettes, they don't offer them, or even standard replacement shafts, for C4 Corvettes.
If such parts are available, at all, I suspect a source like Doug Rippie Motorsports would have them or, at least, know where they are available. Unfortunately, I expect if they are available, they're going to be some high-dollar type, specialty racing parts which is probably not what you're looking for.In Appreciation of John Hinckley- Top
Mike:anybody know of a source for offset a-arm shafts that would allow for more negative camber in a c-4. Old Farm Use needs more --cording front tires at a terrible rate. have gone as far as i can with standard suspention technique to achive camber that's currently not negative enough.mike
Have you removed the "fat" washers in addition to the standard shims?
How much negative camber do you have? I removed all my alignment shims and got to about -1.0 degrees. You'll get much more negative camber by removing the fat washers. (It was not an allowable modification in my class.)
With BFG KD tires I got very even tire wear in many autocross events. Are you running a sticky (DOT or slick) tire?
Bill- Top
Do you need this much:Attached Files- Top
Here's a link to offset lower control arm bushings:
http://www.vbandp.com/detail.aspx?ID=864- Top
