How well does Paragons exhaust tips judge compared to a set of over the counter with the part numbers stamped in them? I know the paragon tips use stainless steel, so that should be a 4 point deduct.
Exhaust Tips 70-72
Re: Exhaust Tips 70-72
You are right about the s/s deduct. I am not not sure if I have looked at one of these yet but if the welds, notch, finish, metal thickness, and other config issues are right then that would be the only deduct. But odds are there will be some of these item's that won't meet the standard and then the judges would deduct points to what the see as incorrect. Paul 18046- Top
I'd bet it near impossible to get a part made out of Stainless that would duplicate the thickness, bends, and messy welds of the originals. Thus Originality would suffer in many respects with a judge who actually has seen originals.Bill Clupper #618- Top
This is a shot of them from the online catalog
Attached Files- Top
Just went through this on the CF. Dug up some pics of one I had that had been removed from a car early on (first design), and had forgotten just how thick the metal was, (not to mention the great weld job
BTW... What is the deduct for someone not having this piece, which was installed on the line to about 14000, and having the second design ?
- Top
- Top
Those first design tips are VERY hard to find. They seldom appear even on Ebay, where just about any other rare part shows up fairly often.
I managed to buy one really nice pair on Ebay, and saw one other pair in poor shape. But these were the only two pair I've seen the last 2 years, and I search Ebay for them daily!- Top
I didn't realize that there were two designs. I always thought that the ones that came on my car, with the welded seam up the middle of the bottom, were the only design. So I would guess that my car, being a very early '71 (Sept 70 build) has the second design tips........ right?
Tom1958, 283/245, White/red - Top Flight, October 2016
2007 Z06, Lemans Blue
Newsletter Editor, Delaware Valley Chapter- Top
serial #14,000(70)-16,000(71) is the running changeI didn't realize that there were two designs. I always thought that the ones that came on my car, with the welded seam up the middle of the bottom, were the only design. So I would guess that my car, being a very early '71 (Sept 70 build) has the second design tips........ right?
Tom- Top
Dennis,
These are the ones from my car. The serial number is 1632, early Sept 70 build. Are they not correct (meaning original) for the car?
Dennis,
I was planning on pulling out the TIM JG as soon as I got home to refresh my memory, but you beat me to it!
Well I have the original tips from my June 70 vert. and yes they are impossible to find. Problem is the previous owner welded the exhaust to them.
Does anyone know of a person that restores the tips other than just plating. What I was thinking is trying to remove the original inlets with a combination of cutting and grinding. Then I would try and fabricate new inlets per originals and weld the new inlets to the tips before having them plated. Maybe make up some type of jig based on another original pair to align the inlet correctly to the tip.
If these tips were not so hard to find I would just replace them. Although it is a real challenge to save them.
Any thoughts? Anyone had the same problem?
Bill- Top
