What do you think, is this a real 4346 fuel pump.
Real 4346
Re: Real 4346
It looks real to me!
HankHank Fredella
Vice Chairman Northeast Chapter
Charter Member (1982)
Webmaster www.necncrs.homestead.com- Top
Re: Real 4346
Hi Ed,
The owner states in answering a question that there is no AC on the bottom cover.An original pump would have this marking on the bottom cover.I also believe that the AC shown at the inlet port is also not correct.
I think a judge would give a small deduct for this pump.
Dave- Top
Re: Real 4346
Ed, ALSO The tapped hole in the center section appears to be 3/8 " pipe thread. Should be 1/4 " There is also a debossed part # on the center section It is 1538354 (just to the right of the outlet hole).
Barry Holmes #940- Top
Re: Real 4346
Two other things that bother me, but I am not sure about them.
1. I sort of expect to see a casting seam around the mounting flange (where the 4346 number is). I have seen two known originals, and both had this flange casting seam.
2. The size of the 4346 looks bigger to me that others I have seen.
Still not sure, but leaning towards a "restoration" 4346.- Top
Re: Real 4346
Re: Real 4346
The one on my 58 has flush bolts, marking on top of flange A C is smaller than shown. AC on bottom. 1538354 stamped on main body.casting # is on forward half of seam on mounting bracket.and is half the size of what is shown in pictuee.- Top
Re: Real 4346
I stand corrected, after crawling under my 57, and scraped away the grease, I found the "AC" on the bottom, sorry about that!
Hank FredellaHank Fredella
Re: Another Real 4346
Joe- Top
Re: Real 4346
Smokey liked to move the fuel line to the outside of the frame rail. The original 4346 is also in the Nassau car. When time permits I will photograph that one too.
Joe- Top
