I need help determining why I can't get a smooth idle during driving. She idles fine in the garage during and after warmup but stalls when I come to a stop after driving for a while. I have initial timing at 10 degrees @ 750 rpms but at that rev. the idle is really rough & non-steady. I set that with the car at normal temperature and after running for about 20 minutes. Currently, I have bumped up the idle to 850 and she still dies when I come to a stoplight. When I came home, I checked the initial timing just for my curiosity @ 850 rpms and it's about 14 degrees. I'm certainly a novice and need some input. In case this helps, I have about 15" vacuum @ 850 rpms. The engine is a fresh rebuild with only about 100 miles on it.
