What are the differences in the 1954 powerglide between a corvette and a passenger car. Different tail housing, etc?
1954 powerglide differences?
Re: 1954 powerglide differences?
the 54(and back) chevy pass cars ustilized a torque tube tranny/rear end assembly, hence the tailshaft and tailstock wil;l differ from the 54 vettes open drive system.mike- Top
Tail housing, output shaft, torque convertor ,side linkage,no cooling lines and the drive shaft will not work using a car PG.
You can use a car PG installed but you need to make up a different drive shaft , block off the cooler lines ,modifying the indicator linkage and buy a safety switch .- Top
OK, I'm dense, so humor me, and tell me what about the following is incorrect:
1. 1963-1955 Corvette powerglides are the same, and will interchange.
2. 1955 and up passenger car cast iron powerglides are different (longer)
than 53-55 Corvette powerglides.
3. 1955 and up passenger car cast iron powerglides can be used in a 53-
55 Corvette, buth the driveshaft would have to be shortened.
Where did I go wrong?- Top
All cast iron PG's weather a 6 or 8 cylinder all can be different like a , Car-Truck- station wagon and so on .Some have a vacuum line while others don't ,some have long tail housing while others don't and so on.If your doing a 53 to 54 (6) you surely need to modifie the drive shaft if it's not the original PG. Same for an (8) depending on what year CAR you use .OK, I'm dense, so humor me, and tell me what about the following is incorrect:
1. 1963-1955 Corvette powerglides are the same, and will interchange.NO
2. 1955 and up passenger car cast iron powerglides are different (longer)NO ALL
than 53-55 Corvette powerglides.Not talking a V8 engine
3. 1955 and up passenger car cast iron powerglides can be used in a 53-Some years and early too
55 Corvette, buth the driveshaft would have to be shortened. 53-54 the drive shaft needs to be redone
In other words if your not using a Corvette PG the drive shaft needs work, and the rear mount also.Yes a car PG will work after some modifications 6 or 8.- Top
Early '63 Powerglides did not have an external oil cooler (or more correctly, they had no oil cooler).
Because there was no cooler, the radiator support for the early PG cars had no hole for the cooler tubing and the radiator shroud did not have a clearance notch for the tubing.
Jim- Top
