Heater core replacement - NCRS Discussion Boards
  • David T.
    • April 30, 2006
    • 46
    I need to replace the heater core on my 66 convertible. I searched the archives and found a thread about a tech article in the Corvette Restorer 2-3? years ago. Does anyone have this article or could you tell me what is involved in the heater core replacement.
    Thank you.
  • Tom H.
    • December 1, 1993
    • 3440
    Re: Heater core replacement
    Hi David !!
    Corvette magazine did a great article with step by step photos in the January 2003 issue. Tech editor, Richard Prince wrote it. 6 pages, full color. If you can't get one, or don't have it, drop me an email. I'll send you my copy. Just send it back when you are done !
    Here's what the issue looks like.
    Tom
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • David T.
      • April 30, 2006
      • 46
      Thank you, Tom. I should have that issue somewhere.
      • Stuart F.
        • August 31, 1996
        • 4676
        Most instructions will tell you you need a helper to hold the inner housing in place while you apply the nuts on the fire wall side, as you are trying to compress the new gasket. Not so. I did it by myself using a roll of duct tape as a wedge between the housing and the cross brace under the dash (the one w/ serial plate and trim tag). Worked like a champ. I too followed the article and it worked well. The big problem is always getting the battery, surge tank, and glove box out of the way.
        Stu Fox
        • Bill I.
          • January 29, 2008
          • 554
          Dave, use great caution around the inlet and outlet tubes. I don't believe they were reinforced for the 66. 67 was. Bill.
