I'm going to build a tach drive distributor over the Winter. I've got parts and pieces from about 3 of them. Right now, I'm inventorying and evaluating what parts I've got, and what I need to order.
1. I've got 3 base plates. They all look fine to me. Looking through the archives, I find a few posts where people advised to make sure the plate doesn't wobble. How do I do that? Without assembling the distributor, is there a way to determine if a base plate is good?
2. How can I tell if the cam is worn? The cam is the part with 8 points that bump the points. Even if the cam is worn, when I adjust the points, won't that compensate for any wear?
3. How can I tell if the drive gear is worn? On both the cams and the drive gears, I can see wear, but not much. Do I care if the drive gear is slightly worn? It's a spiral gear that is driven only one way. When I set the timing, won't that take up any slack?
