Rear end issue - NCRS Discussion Boards
Rear end issue
  • Scott K.
    • August 31, 2006
    • 3
    Rear end issue
    I have a 1965, 327/365, 4 speed. Just recently: When I give the car pretty good throttle, it lunges to the left, sharply. So sharp now, when I correct the steering, it gets the out of control feeling. I notice the right rear tire grabbing. Seems like the rear end is not in synch.
    When I am 2nd or 3rd gear, say 3000 rpm and let off the gas and push in the clutch, it lunges back to the right. Anyone have an idea??
  • Tom H.
    • December 1, 1993
    • 3440
    Re: Rear end issue
    Had a friend with a 65 365 coupe with the same symptom a couple of years ago. Tried everything and finally discovered it was the tires that was making the eratic movements. New tires cure it.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Scott K.
      • August 31, 2006
      • 3
      Re: Rear end issue
      Thanks. I have brand new Coker reproductions, 600 miles on them now. This problem just started in the last 40 to 50 miles
      • William C.
        • May 31, 1975
        • 6037
        Re: Rear end issue
        Check the end play on the stub axles that come out of the rear end housing. I had a retaining clip come off one time and it acted like you described.
        Bill Clupper #618
