Tire mounting / dismounting with Knock-off wheels? - NCRS Discussion Boards
  • Bob S.
    • January 1, 2004
    • 181
    Hello - Is any special technique required when mounting or dismounting tires with (Western repro) knock-offs to avoid wheel damage?
    Bob S.
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    I would certainly have the tire shop use the plastic condom they insert on the mounting arm of the tire machine that seats the tire bead.
    • Bob S.
      • January 1, 2004
      • 181
      Re: Tire mounting / dismounting with Knock-off wheels?
      Thanks Dennis. Could someone please elaborate on this? I asked a very small nearby shop and was shown a "new style" part that removes the tire bead from the rim. It is appearently still metal, but the surface felt a little slippery compared to the "old" piece he showed me. Is this what I need to make sure is used?
      I also called Tire Rack and what they described was basically the same as what I saw at my local shop.......nothing about a plastic insert......or are they just variations on the same theme?
      Bob S.
      • Paul D.
        • September 30, 1996
        • 491
        I think I would check with a shop that sells high end aluminum and chrome plated aluminum wheels. They usually have machines that don't even touch the wheels. Also, I would use a shop tha has been around a while. The guys I used on my C-5 said when they got their new machine, they learned on some poor guy's Porsche. They had to eat 3 wheels at over a grand apiece they said. Expensive training.
        • Bob S.
          • January 1, 2004
          • 181
          To clarify, I guess my question is really whether the K-O's need any more careful handling than the other aluminum wheels I've had tires changed on in the past 10-20 years? The outer bead area of the K-O's just look thinner and therefore more fragile to me....
          Bob
          • Bob S.
            • January 1, 2004
            • 181
            Paul - Good idea!! I'll look for a nearby store that has a "touchless" machine.
            Bob
            • Tim S.
              • May 31, 1990
              • 697
              Bob,
              the piece Dennis is referring to is a "shoe" that goes on to a touchless tire machine. A shop that specializes in higher end cars or custom wheels will probably have one. I recently had the tires on and off of my 65 P48 car to change the valve stems. I had one of my customers (who is VERY careful) do this for me. In fact, he has done others for me as well. A touchless machine is not hard to find at all. The tire retailers will have them and most garages will too. Hope this helps.
              Tim
              • Thomas N.
                • June 30, 1998
                • 45
                Tirerack has a recommended installer listing here:
