My 75 is stored in my garage that is not heated. The last 2 years it was stored in an other garage that was all unheated. I didn't use a cover those years. I want to put my battery tender on it but don't know if having the cover on will cause fumes to build up in the car. Any thoughts?Thanks
Storage question
Re: Storage question
Ken;
Doesn't your cover breath? Do you leave the windows down, or at least cracked open some? If the answers to these questions are yes, I can't see that there is cause for any concern (I assume yours' has the battery in a compartment behind the driver's seat).
Stu Fox- Top
You should be fine with the charger and cover in place. If you continue to have concerns, remove the battery and keep the charger on it, out of the car.
FWIW, I keep all of mine on the battery minders with covers on.Tom Hendricks
Proud Member NCRS #23758
NCM Founding Member # 1143
Specialist for 27 years at BUDS Chevrolet.- Top
