what about this 65? it's near me - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    what do you guys think? look like a real deal car or a piece...
    Re: what about this 65? it's near me
    Pad stamp is funky
    Replacement copper/brass radiator
    Wrong (copper) choke heat tube, intake side tube gone
    Has a '67 hood, rear seal cut too short
    Seats appear to be leather - TT calls for vinyl
    • Brandon T.
      • October 23, 2008
      • 872
      thanks john
      question- how can you tell thats a 67 hood? thought a 65 hood was the same as a 67
        Originally posted by Brandon Thompson (49614)
        thanks john
        It has access holes in the hood inner panel adjacent to the driver's side hinge; those were only in '66-'67 hoods.
        • Wayne W.
          • April 30, 1982
          • 3605
          Has wrong inner-fender on the drivers side, so you can bet its had some body work.
            Director Region V
            • August 31, 1994
            • 1464
            Could be a nice diver, if you are looking for the R D, run away, run away.
            HaND
            • Brandon T.
              • October 23, 2008
              • 872
              looking for the RD ?
              well if it's only going to be a driver I'm certainly not paying 54k for it.
              how can you tell it has the wrong inner fender?
              also john I don't see the holes you're talking about aer you talking about those big areas where you can reach your hand back behind the bolts?
              • Brian M.
                • February 1, 1997
                • 1837
                No big deal but it also has the wrong P/S cap on it.
                • Paul J.
                  • September 9, 2008
                  • 2091
                  The instrument cluster and the steering column could use some work (general condition).
                    Director Region V
                    • August 31, 1994
                    • 1464
                    Hi Brandon
                    Brian has just identified the tip of the iceberg. Even if the pad and tags were not of conern, thousands of dollars and/or a lot of work could be spent just under the hood to make that area presentable for judging. At a glance there are more than a dozen parts, finishes and configuration issues that would need to be addressed first. Since the pad photo of the assembly stamp is cut-off before the suffix, no way to know what this engine is supposed to be. A possible clue, is the Wrapped Temp Sending Unit wire that exits the firewall and runs along the valve cover on the drivers side and crossing over to the sending unit on the passenger side in front of the carb, indicating this may have started life as a base engine, 350's ran along the valve cover on the passenger side, could just be the orientation.
                    HaND
                    • David D.
                      • January 1, 2005
                      • 416
                      Is the tach correct for 350hp car? I thought it had the higher red line.....
                      • Wayne W.
                        • April 30, 1982
                        • 3605
                        The LH inner-fender has a raised pad on it. No 63-65s had this pad. It is a replacement of some kind.
                        • Ridge K.
                          • May 31, 2006
                          • 1018
                          • Brandon T.
                            • October 23, 2008
                            • 872
                            You saying I might should look into it that I might be able to get it a good bit cheaper than that asking price?
                            I can fix a lot of what has been told is wrong with it without much trouble
                            • Ridge K.
                              • May 31, 2006
                              • 1018
