Correct ignition coil for 1973? - NCRS Discussion Boards
  • Christopher K.
    • September 10, 2007
    • 311
    NCRS Tech info manual lists correct coil as 1115270 for 350 engine. My corvette parts catalog lists 1115238, stamped 238-BR as correct for all '67-'74. Is this a replacement coil? NCRS guide says replacements are not embossed, but this one is!
    Need help on this one, and how will it be judged?
    Thanks, Chris
    Chris
    '72 Lt-1 a/c Pewter Silver coupe Mason Dixon Chapter Top Flight 2016
    '73 L82 4 spd Dark Metallic Blue coupe Chapter Top Flight 2023
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: Correct ignition coil for 1973?
    Only a 270 coil will get you the most points. The 238 will get deductions on how it does not meet the judging standard by the number and in any other way it is different.
    Lyle
    • Christopher K.
      • 311
      Thanks Lyle, I'll try to find one. I've got the correct capacitor but Bubba ripped the wire right out of it!
      Chris
      Chris
