Hello, I know this is off topic but it pertains to a possible tow vehicle so I hope it will be allowed. Maybe someone can direct me to a more appropriate forum for the discussion. I am looking at a 1969 GMC 1/2 ton truck. Acording to the glovebox build sheet it is an original 396/310hp, Turbo 400, A/C, P/B, P/S Car. I am trying to find the build date of the vehicle and determine if the 396 is the original motor.
The VIN is CE10D-SA144XX There is no serical number on the Block but the very clear pad with proper broach marks has the stamping T0918YN.
The block is cast H12 ? and the heads I 12 8. The heads are cast# 3933148 which is correct for the 69 two barrel 396. I could not make out the block casting number in the truck. There is a stamped steel tag rivited to the transmission marked CJ-69-3126 and seperately 263 Any help in dertiminig the originality of this set up would be appreciated. There is some rust in the cab but if this is indeed as originally equiped than I think I might go for it. Thanks in advance,
Bill
Bill
