I have a Chevrolet 3 speed transmission. I dont know what it is for. I think I bought it for a spare for my 62 Chevrolet truck. The casting number on the tail housing is 3855710 and an E 106. The case is 3834197 and 12 83 . The side cover is 3849534. I dont know if it goes together or a bunch of parts. It appears to have not been apart. Thank you in advance. Dalel
Chevrolet 3 speed.
Re: Chevrolet 3 speed.
Colvin shows the 4197 main case as used on '64 Corvette (that date code is probably I 28 3), the 5710 tailhousing as used on '65 Corvette, and the 9534 side cover as used on '64-'65 Corvette. Have no clue about truck applications.- Top
If it was installed on a vehicle at a plant, it should have a stamped VIN derivative.
Also, the Corvette ratio set is 2:47, 1.53, 1.00:1, and this ratio set may have been unique to Corvette.
Subtract the number of all transmission options including M-35 from total vehicle production to determine the number of base three-speeds.
Duke- Top
