Re: Correct 58 oil pan
Well heres another question and possibly a diffrerent approach to answering all of our questions. When you look inside of the oil pan with the two large "gussets", it has a baffle on the lowest step and it looks as if GM put these gussets and the baffle there two keep oil from easily coming out of the bottom step where the oil pump would sit, like if the nose of the car was aiming down or on a high sweeping turn the oil would not drain out of the bottom step as easy. Wouldn't a totally flat middle step allow oil to move away from the pump easier? Maybe what GM was trying to accomplish then is what was later accomplished with a trap door? There had to be a reason for these gussets and I would definetely think it would be for performance reasons. FORGET ABOUT THE BOOKS....LOOK AT THE PAN AND TRY TO FIGURE OUT THE FUNCTION FROM AND ENGINEERING STANDPOINT.
sorry that don't concern me and I don't know your answer , that's the number on the print. I'm concerned about a parts design if you followed my postings . The reason I don't bother with numbers like most people do is that to many people go by numbers thinking when buying they will get the right part (NOT) always , that's why I'm into design or a better word to use (what it should look like) . Over and over I've seen people lose money going by the part number and never looking at what the part should look like. Numbers were changed many times over the years on the same part.
Here is that rare 1960 High lift cam, late 60 GM drawing , looking outside of the pan I look for the design and spot welds locations, is the number right you decide.
OK I may have used the last pic. by mistake #640 which is a 57 passenger pan . By the way I'm planing on deleteing many pic's I have in my file so any one wonted to copy better copy I dont know if there kept by NCRS here. Does this help with the arguing?
Notice on the #640 the second step the line curves UP for the detent area CAR
