1969 L-88 question - NCRS Discussion Boards
1969 L-88 question
  • Benjamin C.
    • July 31, 1994
    • 134
    1969 L-88 question
    If an L-88 car was missing the motor is there any way to tell if it is a real L-88?
    Re: 1969 L-88 question
    Sure, trace the owner history of the car back to the original purchaser & delivering dealership. Anything else (doing a forensic examination of the car's configuration today) is dubious at best....just about everything can be 'faked' to make a car appear to be a real McCoy L88.
    • John C.
      • January 1, 2005
      • 616
      With out actual confirmed documentation no one thing can tell you if it is a real L88. This is true even if you have the engine.
      Some of the things that I would look for are:
      L88 hood.
      Unique Aluminum radiator (if manual transmission)
      Modified core support
      Dual pin J56 brakes
      No radio
      Single fuel line
      403 bell housing
      must have TI ignition
      HD 7 spring suspension in rear
      6500 RPM red line on tac
      John
      • Wayne M.
        • March 1, 1980
        • 6414
        Originally posted by John Carlson (43123)
        that I would look for are: .......
        And even early '69 L88's would be without the suffix if the trans was assembled in Muncie before 21 Oct 1968 (applies also to all 4-speeds).
