After replacing the driver side rear axle bearing ( failure after 7000 miles) for a friend we were wondering why the failure. Everything seemed to be in order, however after driving the car on the freeway I checked wheel hub with an IR gun and found that the drivers side is about 45 degrees hotter that the passenger side. (145 to 100, this on a 60 degree day)Made sure the brake shoes were not dragging, inspected everything we could think of and found nothing. The rear end is a 56 with a 62 posi third member in it. Any ideas as to why one side runs so much hotter than the other. Is the driver side not getting lubricated for some reason?
