I'm assessing parts that can be salvaged or need replaced prior to tear down. I have a 69 350/350 Copper radiator with the original shroud (3956109).
Mine is servicable, but has been painted over and is showing it's 40 years with several run in's with the fan on the edge in it's day.
Obviously, I'm looking for a crisp and fresh engine bay and I'm doubting if these are even being reproduced as most had the Aluminum set-up with Surge tank.
Likely even more difficult restoring one and sanding with some 00 steel wool while trying to maintain a molded plastic surface appearance.
Any leads on reproductions or tips on refurbishing the fan shroud?
