Re: BB - Replace high pressure oil pump?
I looked up this Sealed Power pump on Summit Racing's web site. In the picture, if you spin it around, it says M77HV! Mellings seems to be the only game in town.
I called Mellings technical support and talked to George. He recommends the 10775. It comes with the 75 # pink spring. He says to change it out for the 60 # blue spring. I may not have this quite right, but he said something like "the 10775 has a little better control of shaft wobble than the 10774." He did say for sure that the 10775 is better at high RPM than the 10774. He mentioned that the 10774 and 10775 both have the same steel gears. He said the pickup tube to try is P/N 77S1. There is some conflicting documentation as to whether or not it will fit. He thinks it will as long as I still have my original six quart pan. He did recommend taking measurements, possibly with clay, to make sure. He also said that he did not recommend using any of their high volume pumps on my car (M77HV, 10770, 10778). He also said that he thought the high volume pumps would cost me roughly five HP over the standard volume version.
Hopefully this clears up more confusion than it causes!
Joe
Joe
