Quadrajet help - NCRS Discussion Boards
Quadrajet help
  • Jeff W.
    • November 1, 2005
    • 272
    Quadrajet help
    I am not sure if this is appropriate to ask here, but does anyone have or know where I can locate a bowl for a 2203 quadrajet dated E, D or F 2? Not going to say how I screwed mine up (just got it back from being restored), but I did.
    Thanks so much for the help.
  • Lyndon S.
    • April 30, 1988
    • 1027
    Re: Quadrajet help
    Oh you got tell us how you screwed it up, other wise we cant help you come on fess up that is how the game is played.
    ________
    Kelly
    • Jeff W.
      • November 1, 2005
      • 272
      Re: Quadrajet help
      No laughing though!! I unscrewed the fuel inlet to see if there was a new fuel filter in it (I know, Tom at Custom said the same thing) when I went to screw it back on I somehow didn't alighn it an stripprd the threads! There, are you happy! I was sick. Now, can you help me?
        • 15573
        Re: Quadrajet help
        Jeff,
        Contact the place that did the restoration. They may be able to repair the threads. If they can't do it, I have the contact information for a carb shop in the Rockford, IL area that can probably put a Helicoil in there.
        • Lyndon S.
          • April 30, 1988
          • 1027
          Re: Quadrajet help
          • Dave S.
            • August 31, 1992
            • 2918
            Re: Quadrajet help
            Jeff,
            You are in good company. That problem is all to common. As Terry said you can have a helicoil installed. Bob Kunz developed another fix that uses an "O" Ring. He did my Camaro Q-Jet that way several years ago and it worked quite well. Just another option.
            • Jeff W.
              • November 1, 2005
              • 272
              Re: Quadrajet help
              Thanks guys, I have sent it back and they are try to do the Heli coil. It doesn't look like it is working. They are trying to find a bowl as well, I was just trying to hedge my bets. I haven't messed too many things up, but this one was tough to take.
