66 Coupe Fenderwell Undercoat - NCRS Discussion Boards
  • Greg T.
    • January 1, 2004
    • 136
    Does anyone have a picture of a front and rear fenderwell to see where the undercoat covers? The NCRS manual is a little hard for me to decipher. Is the the power antenna mounting plate or aluminum rivets present during undercoat? Thanks in advance.
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 66 Coupe Fenderwell Undercoat
    This shows the front wheel well on an in factory body. You will notice it was done even before blackout. Coverage varied from none to a lot, depending on timing, body plant, and just who was on the line.
    • Mike M.
      Director Region V
      • August 31, 1994
      • 1464
      Greg,
      While you are waiting for a pic, the undercoat was irratically sprayed in a sweep, to keep rocks from causing top surface chips and cracks.
      Antenna plate and the #3 body mount access plate were installed after undercoat.
      Which rivets are you referring to?
      HaND
      • Tony S.
        NCRS Vice President, Director Region VII & 10
        • April 30, 1981
        • 969
        Great photo!
        Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
        Original member of the Kansas City Chapter, est'd 07/11/1982.
        Member: 1965 and 1966 National Judging Teams
        Judging Chairman--Kansas City Chapter.
        Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
        • Stephen L.
          • May 31, 1984
          • 3148
          It also appears the radiator support was installed before paint etc. Was the radiator also installed????
            No, the radiator wasn't installed prior to painting. The core support WAS installed to provide structural rigidity to the nose of the car as it traveled on its 'mule' through the paint booth...
            • Tony S.
              • April 30, 1981
              • 969
              Original cars usually have paint overspray on the underneath side of the core support and on the three nose supports that are attached to the bottom of the front core support.
              • Greg T.
                • January 1, 2004
                • 136
                Originally posted by Mike Murray (25129)
                Greg,
                HaND
                The aluminum rivets that hold the header tank bracket and the wiper reservoir on the front fenders. Were they installed before undercoat? I wouldn't think so but.......
                • William C.
                  • May 31, 1975
                  • 6037
                  Most of that stuff that was riveted to the inner fender (brackets and the like) were done prior to the assembly of the body panels, so yes, the rivet heads would be covered with blackout. Attached picture should show what I mean, Rivets for brackets and such all sprayed.
                  Bill Clupper #618
                    That issue (body paint overspray on the bottom of the rad core support) is more important to '63-65 cars than '66-67. Why?
                    Well, the core support changed in geometry to accept copper/brass radiators that were taller than the earlier aluminum radiators and the solution was to angle the radiator back more steeply in the nose of the car.
                    When this was done, the bottom of the core support was effectively (not TOTALLY) 'masked' by the lower front fiberglass... But, the early cars were pretty 'ugly' in terms of body color overspray (blobs, runs, sags, Etc.) on the bottom side of their radiator core supports with paint coverage running in lock-step to the coverage on the adjacent front lower fiberglass panel.
                    • Greg T.
                      • January 1, 2004
                      • 136
                      Thanks for the great pictures!
                        Greg -
                        ALL of the peened soft aluminum body rivets were installed in the Body Shop, prior to paint.
