Warning: Undefined array key 0 in .../vb/user.php on line 530
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 530
Warning: Undefined array key 0 in .../vb/usercontext.php on line 221
Warning: Trying to access array offset on value of type null in .../vb/usercontext.php on line 221
Tar Top Battery -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
A recent NCRS Flight judging on my '56 Corvette had points deducted because the car did not have a "Tar Top" battery. Can anyone direct me to a source of a correct Delco model 2SMR53 tar top battery?
Don, The Summer 2008 issue of the Corvette Restorer has an article on how to Tar Top a DRY CELL battery. DO NOT try this with a lead acid battery. The gases from the electrolite will explode.
Best of luck.
Scott
#2379
