Some one used a cutting torch on my motor mounts, is there a manufacture that reproduces them?
C2 Motor Mounts
Re: C2 Motor Mounts
I did not know the correct term, but yes it is the portion of the motor mounts that is welded to the frame. Some one used a cutting torch to remove the bolts at one point, the car was stolen once.
I need to replace or repair the frame horns if that is what they are called.
Thanks for your help on this.- Top
Re: C2 Motor Mounts
Dave-----I did not know the correct term, but yes it is the portion of the motor mounts that is welded to the frame. Some one used a cutting torch to remove the bolts at one point, the car was stolen once.
I would check with Vette Products of Michigan (www.vetteproducts.com). I'm almost certain that they reproduce the parts you need.In Appreciation of John Hinckley- Top
