69 alternator - NCRS Discussion Boards
69 alternator
  • Lynn S.
    • November 1, 2004
    • 99
    69 alternator
    Rebuilding original alternator for my 69 L89 #8804. Question: What is the correct finish for the alt pully and fan. Also my pully and fan have a slot for a metal key but the shaft on the alt has no slot?? Also the upper brace looks like two 1/4" brases welded together making it 1/2" thick. Correct or not? Thanks, Lynn Schwebach
  • Dick W.
    • 10483
    Re: 69 alternator
    Cad/zinc for the pulley. Brace should be one piece, about 1/4"- 5/16" thick
    Dick Whittington
    • Lynn S.
      • November 1, 2004
      • 99
      Re: 69 alternator
      Thanks Dick, do you know if the pully and fan is supposed to have a key slot? Lynn Schwebach
        Re: 69 alternator
        Lynn-----
        The alternator fans did have a keyway. However, I don't recall any of the pullies having such a keyway. It's possible that some did, though. In any event, if a pulley is otherwise correct, I wouldn't be concerned if it had a keyway, or not. The keyway is, of course, unused and its presence will not be visible when installed.
        • Lynn S.
          • November 1, 2004
          • 99
          Re: 69 alternator
          Joe,
          After several house in lac thinner the paint etc came off the pully and it has the correct part number so I will not worry about the key slot. Thanks, Lynn Schwebach
            Re: 69 alternator
            Joe,
            Lynn----
            Could you post a few photos of the pulley?
            • Lynn S.
              • November 1, 2004
              • 99
              Re: 69 alternator
              Joe,
              I have three pix of the 69 alt pully/Fan but cannot get thru this site. send me an e-mail to lynn@unclejakesfurniture.com and I will reply with the pix. Also have some pix of misc AIR parts I am selling if you are interested. Lynn Schwebach
