Does anyone have pictures of original u-joints for a 1970?
1970 U-joints
Tags: None
- Top
Re: 1970 U-joints
Hi Stephen,
For frame of reference only; my 71, #6589, January built, SB, has SPICER written on the end of the cap with the letters in an arc. They are the original u-joints.
PS: I hit enter too soon.
The above is for the DRIVE-SHAFT u-joints. The HALF-SHAFT u-joint caps are plain/smooth on the end.71 Coupe, 350/270, 4 speed
Chapter Top Flight October 2011- Top
Re: 1970 U-joints
Thanks Alan. I'd love to see the "Spicer" on the u-joints if you or someone has a picture.- Top
Re: 1970 U-joints
Stephen-----
I don't think that all u-joints used on Corvettes of the period did have the "Spicer" brand name embossed on the caps. I believe that some were either manufactured by Spicer with NO reference to Spicer on the joint AND with "GM" embossed on the body of the joint OR they were manufactured by some internal GM division. Personally, I think it was the latter. This applied mainly to the half-shaft u-joints, but I believe it included driveshaft u-joints, as well.In Appreciation of John Hinckley- Top
Re: 1970 U-joints
Here are some joints out of my 69. The restored joint used to look like the old cruddy one on the left. It's amazing what one can do with a mild solution of muriatic acid, a stainless steel brush and some patients.
If you would like full size pics just send me your e-mail and I'll send you some.- Top
Re: 1970 U-joints
Were the bearings inside the U-joints still good?Here are some joints out of my 69. The restored joint used to look like the old cruddy one on the left. It's amazing what one can do with a mild solution of muriatic acid, a stainless steel brush and some patients.
"Most" old ones I've seen have turned to rust powder and are useless.
PatrickVice-Chairman (West), Michigan Chapter NCRS
Re: 1970 U-joints
Greg,
Please send me the pictures to BunkyByrd@aol.com. I appreciate it.
Joe,
The 70-72 judging manual states that the half shaft joints had Spicer on the caps, but it does not say with regard to the driveshaft. I was curious to see what a Spicer stamped cap looked like.- Top
Re: 1970 U-joints
Greg------Here are some joints out of my 69. The restored joint used to look like the old cruddy one on the left. It's amazing what one can do with a mild solution of muriatic acid, a stainless steel brush and some patients.
These look like 68-70 THM-400 driveshaft u-joints. Is that what they are?In Appreciation of John Hinckley- Top
Re: 1970 U-joints
Greg-----
Several things. The apparent size of the bearing caps, the apparent width of the fingers, the "depressions" in the center of the body of the joint, and the fact that they have "Spicer" on the end caps.In Appreciation of John Hinckley- Top
