Electrical Wiring Harness Regulator to Gen - NCRS Discussion Boards
  • Stewart A.
    • April 16, 2008
    • 1035
    Some time back I took my wiring harness off my reg to generator. I have purchased a new wiring harness but can't remember where the earth strap goes to the regulator. I thought it come off one of the 2 screws that hold it to the body but the new attachment hole in the earth strap is to small for the screw, so I'm thinking it doesn't go there. So now I'm lost where does it go. I'm not sure if it makes a difference the car come with a radio or not. Help!!!!!
  • David D.
    • December 1, 1977
    • 231
    Re: Electrical Wiring Harness Regulator to Gen
    Stewart -
    The braided ground 'eye' will attach to the generator casing with a fine thread bolt with possibly an offset E. The threaded whole is approx. 2 inches forward of the 'A' terminal on my 2173 generator.
    David Dawdy
    • David D.
      • December 1, 1977
      • 231
      Sorry, I jumped the gun. The other end goes to the top screw holding the reg cover.
      David Dawdy
      • Stewart A.
        • April 16, 2008
        • 1035
        David I just want to be sure you say the earth strap attaches to the top of the regulator cover not the regulator body. The cover screw will fit so it does make sense. Thanks David
        • Mike E.
          • February 28, 1975
          • 5134
          Cover is correct. Later on they made a provision for attaching to the body of the regulator.
