Noticed the lower two bolts (3847758) on the hood hinge are different from the upper three (3846201) The repro are all the same, the lower longer ones (3847758).
The top three are shorter without the pointed end, however the head markings appear to be a large "G" with an "L" inside. Have not seen this mfg mentioned before. Yes the hood has been off a few times and one bolt is an "E" head which was cut short to look like the "G L" bolts. Are these "G L" bolts real for 1963-64 time??
Has anyone had problems using the longer 3847758 repro bolts - do they go through the hood??
PS - in the past I believed the hinge was never painted, however the bolts appeared to be a black finish, but it was really paint. So I guess the hinge may have been painted and somebody just cleaned them really good. (not an AOS car)
