Re: L71 L72 427 Running on Pump Gas
4.28" x 3.76"
zero deck clearance (nominal OE is .020", NHRA mininum is .008")
.070" x 4.35" gasket (bore hole dimension is an estimate)
106.9 cc head chamber (NHRA minimum - I don't know the OE nominal or your actuals)
30 cc net dome volume
The cgnetwork calculator yields 10.436:1 - everything the same with .035" gasket thickness is 11.377.
I didn't see that you listed the head chamber volumes you measured. What were they?
I suggest that you measure one more piston dome. If the results are consistent with the first one you measured, I would go with your measurements rather than the 35.5 cc "spec".
4.28" x 3.76"
It is simple if you use the system I talked about earlier. Install the crankshaft, one rod and one piston with only a top ring. Pack white lube into the area above the ring to seal it. Install a used head gasket and the cyl head.
