54 tachometer calibration - NCRS Discussion Boards
  • Joe R.
    • July 31, 1994
    • 287
    Trying to recalibrate my 54 tach. It reads really low now. Any tips on how to do? Anyone know the ratio of the unit?
    Joe
  • Loren L.
    • April 30, 1976
    • 4104
    Re: 54 tachometer calibration
    Give it up; at any speed above 50mph, the best one ever made MAY be 500 RPM in error.
    • Joe R.
      • July 31, 1994
      • 287
      Mine's far worse. At around 3,000 RPM, it reads about 1,200.
      • Brian T.
        • September 30, 1990
        • 188
        I disagree, they can be quite accurate if calibrated properly. This of course requires a magnetizer, demagnetizer, and speed comparator. The ratio of the tach is twice cable speed because it is driven by the distributor. The generator driven units are calibrated cable speed.
        • Joe R.
          • July 31, 1976
          • 4547
          Joe,
          Do you have several thousand dollars of calibration equipment sitting in the corner of your garage? If you do, I would like to purchase it since you will only need it once in a lifetime.
          SEND the tach to someone that has the expertise and give up the bucks!
          You will NEVER be able to do it without the correct calibration equipment.
          JR
          PS. Brian has the equipment to do the job correctly! Give it up!
          • Joe R.
            • July 31, 1994
            • 287
            GEEEEEZ JOE, I'm just trying to do it myself!
            Seriously, thanks for the advise all. I'll send it out .
            • David D.
              • January 1, 2005
              • 416
              Joe
              Joe,
              I just had my gauges re-rfurb'd and I know the guy ended up using magnetizer, demagnetizer, and speed comparator to complete the speedo and tach in my situation, and I couldn't be happier..... I know he does all C1 - C3 gauges.....
              Call Bill at (561) 676-3099 and he'll give you all the info you need and how much, but it'll be done right.
              This website is for sale! harrisonspeedometer.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, harrisonspeedometer.com has it all. We hope you find what you are searching for!
              David
              • Jack H.
                • April 1, 1990
                • 9906
                Deluxe Speedometer in Denver is our local 'go-to' guy for speedo/tach work. He's an old timer, United Delco, dealer and has the Delco factory authorized calibration machine(s) to do this work. A typical fee is in the $50 range with parts being extra (double check current rate), but he does NOT do 'cosmetic' refurb work (fresh silk screen on the face, Etc.).
                If you're interested in contacting them, simply key the name into your search engine or use an electronic phone book to look up the address/phone...
