1967 VIN /build Date Help - NCRS Discussion Boards
  • Mark F.
    • May 11, 2008
    • 68
    Re: 1967 VIN /build Date Help
    John,
    Thanks. It is a ST. Louis car.
    Mark
    • Gerard F.
      • June 30, 2004
      • 3803
      Mark,
      For what it is worth, the VIN (last five) on my 67 convertible is 22049 with a birthday of June 29, 1967 (Thursday). The body build date is K19(June 19), but it is an A O Smith Body build which would account for the lag in time.
      My small block engine is dated 06/26 (V0626HE for a base engine).
      Jerry Fuccillo
      • Mark F.
        • May 11, 2008
        • 68
        #18
        Jerry,
        Thanks, that actually helps. With this being a St. Louis body. Does your your body number correspond to the body build date? Somehow?
        thanks again
        Mark
        • Mike M.
          Director Region V
          • August 31, 1994
          • 1463
          #19
          Yes, Mark, that VIN from the frame makes sense.
          All the numbers now tie together in typical sequence.
          HaND
          • Rick S.
            • January 1, 2003
            • 1203
            #20
            My 67 St.Louis body build date is K16. The VIN is 21135 and the C2 registry gives it a June 17th (Saturday) birthday. The Wisconsin NCRS site gives it a June 19th (Monday) birthday.
            My 327/350 L-79 has engine date of June 5th (V0605HT). The block casting date is E317 (May 31,1967).
            Rick
            • Gerard F.
              • June 30, 2004
              • 3803
              #21
              Originally posted by Mark Fedeli (49007)
              Jerry,
              thanks again
              Mark
              Mark,
              The body number on mine ought to correspond to the body build date, as I will have had this car 40 years this month. But the number is only the sequence number at AO Smith, only somewhat related to the car production date. It is A-4837 for a K19 body on mine.
              What engine does the car you are looking at have in it now, and is it a small block body or big block body.
              If you are looking to the restore it, without the original engine or transmission, you are probably in for a big time job. If you just want a driver as is, it might be a good deal.
              If it is a big block, you might want to get someone to look at it, if you have restoration in mind. With the mis-stamp in the VIN, and NOM, I think I'd pass it up, unless it is a super deal and you just want a driver
              Jerry Fuccillo
