New camshaft installation - NCRS Discussion Boards
  • Rex T.
    • December 1, 1984
    • 455
    What are the recommendations for installing a new hydraulic camshaft in a new big block engine (427-390 horsepower)? Looking for tips on cam break in, should lifters be soaked in oil prior to installation, cam lube for break in, etc etc. Any and all suggestions / advice requested.
    Thanks in advance for your help.
    Rex
  • Thomas H.
    • August 31, 2005
    • 1053
    Re: New camshaft installation
    Rex
    Rex,
    When using a new flat tappet hydraulic cam, I have always had success following the cam manufacturers recommendations regarding installation and break in. Most cam manufacturers have detailed instructions on their web sites.
    Tom
    2007 Z06, Lemans Blue
    • Tim S.
      • May 31, 1990
      • 697
      Rex,
      I also follow the manufacturer procedures. One item to add though. You will want an oil additive from a cam manufacturer (Crane, Comp Cams, Etc.) for additional lubrication and protection of the lobes in that critical first 20-30 minutes.
      Tim
      • Thomas H.
        • August 31, 2005
        • 1053
        Rex,
        One other thing, check the archives. I'm sure you will find some great information there from some very experienced engine builders that frequent this forum.
        Tom
