hi guys,
I have a 59 fuelie 290 hp and am about to install the correct heads with the help of a friend. I have checked the lifters and believe that they are solid lifters. I also contacted the owner of the car from before the previous owner, who actually rebuilt the engine. He could not remember for sure if the cam was the early Duntov cam or not. So I see on some other threads that depending on what cam you got, there are four different possible valve lash settings as suggested by Duke Williams:
Now I read that if I make the valve lash too loose, then the valves will rebound to fast and end up beating up the valve seats and if I make it too tight, they won't close all the way and end up burning them out. So what is the best course of action? Seems like looser is better than tighter...
If I set it too tight vs too loose what might I hear or detect from the engine to know I'm on the wrong track, before really screwing something up?
Is there any way to tell if I have an 097 cam or otherwise by pulling the oil pan?
thanks!
thanks!
