'67 Harrison air conditioning tag coming off - NCRS Discussion Boards
  • Larry S.
    • March 11, 2007
    • 457
    My original Harrison air conditioning tag on the firewall is slowing coming off. It's curled up on three corners and about 25% off. Any remedies? I assume there's engine engine gases/grime under it that's slowly lifting it off. I suppose a 25% lack of adhesion after 41 years isn't bad, but I sure would like to save it.
  • Loren L.
    • April 30, 1976
    • 4104
    Re: '67 Harrison air conditioning tag coming off
    Lay a tube of clear expoxy clue on top of the A/C and see if the elves come out at night and get the job done.
    • R N.
      • May 31, 2002
      • 640
      Try 3M's spray adhesive, I've used it for other applications and it works well. Just mask the area around the label and follow the instructions on the spray can. Good luck.
      • Lorne G.
        • June 30, 1988
        • 118
        Larry don't make the same mistake I made by waiting too long to fix it. I had the same problem last Fall except my label was about 70% off and rather than fixing it then I kept putting it off thinking I would fix it during the winter......guess what? it blew off sometime during one of my last Fall drives.
        Lorne
