I have been comparing my 9-Leaf rear spring for my 1964 convertible to the description in the Tech Information Manual (NCRS) and its close but there are a few things that make me think it's a replacement. (1) It's black and there are no signs of gray under the black paint. (2) The last three leafs are flat and the TIM says just the last two are flat. (3) The 45 deg angle cuts on the ends of the main leaf are different on one end than the other. One end looks correct but the othere has a small arc to the cut almost like the shear had a radius to it. I would guess it;s not original but I need some backup from the wealth of experience at NCRS.
Assuming it is not original I would like to replace it during the frame off I'm currently doing. Who makes the best reproduction?
I bought the Eaton, took off the bottom leaf only and used it on my original 63 spring. Also, took the top 3 leaves and used them too.
