Hi,
I recently bought the correct 3755550 heads for my 59 290 HP fuelie. I decided to figure out the Compression ratio on them and came up with only about 7.7, which ends up being about 265 HP. I measured the CCs of the heads at 69cc. Would GM have machined different sizes of combustion chambers on these heads for the various horse power engines on corvettes in 1959? I'm afraid I got the right heads, but machined for low horse power, which being a newbie I didn't account for
Is it possible (or even advisable) to have a machine shop fill in the chambers and machine new ones?
I have another set of heads, which were wrong, but even those are 64cc, which also seems too big.
Also, the pistons sit very low, about .05 under the deck, but I measured with the bottom of a digital caliper, not having a micrometer yet. Seems like I'm going to have way too much quench too, even with a .015 shim...
I got my numbers like so:
piston bore: 3.915
stroke length: 3
gasket bore: 4.1 (Felpro metal shim gasket)
gasket thickness: .015
combustion chamber: 69
dome volume: -5
deck clearance: .05
So now I'm wondering does it make more sense to have the engine rebuilt with domed pistons or to try to get the right RIGHT heads (even though I paid to have these rebuilt already), or just take my beating and put the heads on and shrug?
Is it possible (or even advisable) to have a machine shop fill in the chambers and machine new ones?I have another set of heads, which were wrong, but even those are 64cc, which also seems too big.
piston bore: 3.915
stroke length: 3
dome volume: -5
deck clearance: .05
I remeasured and it is indeed 60cc. So my compression is 8.6. Mostly due to the deck height being so high at .05. With my shim gasket of .015 that makes the quench .065. If that quench is accurate, will it cause issues?
