1967 C2 Brake Line Torque Specs in AIM - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2126
    On the Assembly Instructions (AIM) page showing only brake lines and fittings, there is a what I see as a torque spec. or "footnote" number 7. This is at the lower left of the drawing for rear brake lines, 1967 Corvette.
    On the drawing, the 7 (inside a triangle) points to the connection of the flexible hose into the line connection block attached at the tab on the frame.
    How could that be torqued to 100-125 LBS.IN? Wouldn't that be excessive torque?
    td
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • Michael H.
    • January 29, 2008
    • 7477
    Re: 1967 C2 Brake Line Torque Specs in AIM
    td
    Tom, 125 LBS IN is INCH pounds, not foot pounds. Converted, that would be around 10 foot pounds.
