My car is a 57 FI car and I'm trying to install an exhaust pipe kit that I bought from Corvette America a couple of years ago. It is supposed to be correct for a 57 FI car.
The issue I'm seeing is this. When I add the heat riser spacer on the right side exhaust manifold it appears to make the right side exhaust pipe too low. I'm basing this by measuring from the floor to the cross-over pipes. It is off roughly the width of the spacer.
Does anyone know if Corvette America made an exaust kit that would compensate for the spacer by having a slightly longer right hand pipe? The kit I bought was p/n 35484.
Or is the right side supposed to be slightly lower than the left side?
Any thoughts are appreciated.
p.s. FYI - The '57 FI exhaust spacer should have "TOP" on it not "UP".
