C2 Upper Cowl Restoration - NCRS Discussion Boards
  • Dave G.
    • February 21, 2007
    • 14
    I removed the two air inlet grilles in the upper cowl wiper arm area. I noticed the interior of the cowl under the grilles appears to have some corrosion taking place on the bottom front seam. I would like to clean this area up and reseal it, it is currently painted body color. From what I have read it should be painted black. Has anyone else had this problem and what is the best approach to repairing it?
    Thanks in advance for your help.
  • Douglas L.
    • August 31, 2003
    • 299
    Re: C2 Upper Cowl Restoration
    Hey Dave,
    The only metal in the upper cowl are the wiper pivots. The upper cowl is all fiberglass. What you might be seeing is the factory tar sealant that was "gooped" and "poured" in there by the factory with zero emphasis on beauty. The area was sprayed with body color and then "blackout". What usually happens is the old paint on the tar sealant begins to crack and peel which doesn't look good. But, no corrosion should be going on.
    • Tom D.
      • September 30, 1981
      • 2126
      For this "black-out" area, I think I have some photos on this web-site (see link below). If not there, I have some in my mac iPhoto library...
      td
      https://MichiganNCRS.org
      Michigan Chapter
      Tom Dingman
      • Tom D.
        • 2126
        Here is one of the three photos I referenced.
        td
        Michigan Chapter
        Tom Dingman
