67 power window wiring - NCRS Discussion Boards
  • Mike P.
    • May 31, 1992
    • 25
    I need some help with power window harness. There is a brown wire behind glove box that has a black connector with two connections coming out of both ends. Schematic shows it as being radio capacitor connector ? In the aim A-31 it also shows as radio capacitor connector, but it is closer to drivers side. I believe there is another radio capacitor connector coming off of main harness in same area. Any help greatly appreciated. MIke
    Re: 67 power window wiring
    Mike -
    See my response to your other post on the same issue.
    • Mike P.
      • May 31, 1992
      • 25
      I think i got it now, went back to aim A-31 A1 it shows a # 19 ( tape approx 6 in. radio capacitor lead to inst. panel harness) so iam guessing that is my missing third wire ( there really isnt a wire in harness it is a taped on capacitor). AIM is real confusing and unclear on some of this stuff. On u-69 A4 the middle wire must be the capacitor wire, but there is a # 6 caopacitor in same area mounted with screw (3844184 capacitor asm. locate connector on tan wire & secure with pin), any idea what this is for. secure with pin, etc. ? Thanks for your help Mike
        The "secure with pin" capacitor goes on the tan wire to the "Brake" warning light in the cluster; the connector is just like a 3M "Scotchlok" connector - you squeeze it with pliers so the pin pierces the wire.
