1963 master cylinder - NCRS Discussion Boards
  • Timothy B.
    • April 30, 1983
    • 5177
    Is it possible to convert a non power brake M/C to power brake and properly drill and install bleeder without damage. I am wondering if anyone has done this before.
    Are there any other differences other than the bleeder and bolt in place of the thumb screw?
  • Joe R.
    • July 31, 1976
    • 4547
    Re: 1963 master cylinder
    Not only is it possible, it has been done on many occasions before. And no there are no other differences.
    JR
    • Timothy B.
      • April 30, 1983
      • 5177
      Can you tell me if they used the bolt securing the lid on the early cars? My car is built November 62 and I am thinking about installing power brakes if I can find a nice booster. Also, how hard is it to install the plate at the firewall and buck the rivet?
      Thanks, Tim
      • Gerald C.
        • June 30, 1987
        • 1273
        Joe,Do you know what size the thread is and the bleeder screw?Also Tim, My car is an October car so your question of the thumbscrew or the hex head is important to me. Did you ever get an answer?Thanks,Jerry
        • Bob R.
          • June 30, 2002
          • 1595
          Tim, when I installed the plate at the fire wall I just used a little glue to hold the rivets in place and the two bolts actually hold it. I couldn't see any way to buck the rivet and not damage something.The reason they went from the thumb screw to the bolt is the thumb screw can hit the hood when closed. So you may want to use some caution when closing the hood if you go that way.
          • Harry S.
            • July 31, 2002
            • 5258
            There are several known 63 cars that have the mounting bracket pop-riveted on. Use a pop-rivet and spray it with blackout.
            • Jim L.
              • September 30, 1979
              • 1805
              Original master cylinder and booster on my '63, #3493:
                • 6940
                Jim was there more than one part number for boosters in 63? the no 3493 is that stamped on the booster? I know the judging manual calls out for No. 2574
                • Jim L.
                  • 1805
                  Sorry for not being more clear. 3493 is my car's VIN.
                  Jim
