I've got the diff out and on and engine stand. I have to replace the rear cover (not a HD to keep orig.) since the ears are broken in the usual spot.
I was thinking of replacing the drive shaft seal and the side yoke seal and needle brgs as preventative measures. Can the brgs be replaced by removing the C-clip, pull the shaft out, use a brg puller to get the needle brg out, then replacing everything.
The original seals are not leaking and the brgs seem OK. Or is this effort to much since it seems OK anyway.
Steve L
73 since new.
Steve L
73 since new.
I replaced it and decided to replace the 3:55's with 3.90's. I am seriously considering pulling this one out and replacing with a HD aftermarket. 'anyway, it pays to check these things.
