67 Convertible top adjustment - NCRS Discussion Boards
  • Lorne G.
    • June 30, 1988
    • 118
    Hi, can someone please advise me on the best method to adjust a convertible top or direct me to a sight outlining the procedure.
    I recently took the softtop off my 67 to have the body painted and I noted the location of the bracket and bolts on the car for the replacement. I just re-installed the softtop and now it is very tight. I can barely latch the top closed with the pin at the higest position and can not close the latches with pin lower in the catch where it should be.
    I am not sure if I need to raise the mounting bracket slightly or to move the bracket forward slighlty. The top had a real nice fit before and I am afraid to loosen it to much and cause a poor saggy looking fit.
    Thank you.
    Lorne
  • Kirk M.
    • June 30, 2006
    • 1036
    Re: 67 Convertible top adjustment
    Lorne,
    The two sets of screws that mount the convertible top the the sides of the car (interior) just behind the seats are the screws I would try first. Loosen them slightly and move the top up and down, this will permit the whole top to raise/lower and move slightly forward/backward with each adjustment. Get those set correctly and then adjust at the pins both front and back. Hope that helps.
    Kirk
    • Lorne G.
      • June 30, 1988
      • 118
      Thanks Kirk,
      I will loosen the side mounting screws and try to make the adjustments. i was wondering if i should make the adjustments with the top latched or unlatched and latch only for fitment test.
      Lorne
      • Kirk M.
        • June 30, 2006
        • 1036
        I did mine unlatched. I would adjust the side, tighten enough to hold the position and then check the front pin alignment and then the rear deck latches. Took a few times, but I eventually got it right.
