I purchased a very used '96 LT4. The passenger seat adjuster suffers from the common stripped plastic gears problem. GM list two separate part numbers for the driver and passenger seat adjusters (oft referred to as the seat track). I was expecting them to be the mirror image of one another but the two adjusters (tracks) in my car are identical. Since the adjuster assemblies do not have the part number stamped on them anywhere I can't tell if I have the correct parts in my car. Since they are both configured the same, I suspect that a previous owner replaced one of them with a track for the opposite seat. My questions are:
- Is my assumption correct - i.e. the seat adjuster/tracks should be the mirror image of one another?
- If this assumption is correct, is the gear housing supposed to be on the outboard or inboard side of the seat?
Thanx in advance,
-Floyd-
Thanx in advance,
-Floyd-
